You need the third earth pin to open the blockers on the live and neutral, wouldn't go into the socket without it.
When what jams? it's a simple device. And it has a fuse.![]()
Looks a bit flimsy, what if you kicked it side on by mistake, wouldn't it be dangerous to try and remove it from the socket if you had to place something between the socket and the now flat plug?
Re chargers, I don't think it would work for small chargers (mobile phone etc), .
Also fuses don't get hot, so I don't see why you wouldn't use it with heavier equipment.
So explain how a fuse works then? The internal wire fails over a certian current by heat, thats why they have the fire proof cladding on them.
KaHn
KaHn
The great british plug - even greater when you step on it bare footed!
