I'm posting this as I've tried everything I could immediately think of:
I have a laptop, a HP dv9655ea. It won't post. All I get is a black screen and the machine stays on until forced off by the power button. Specs of interest are as follows:
AMD Turion 64 X2 2.0 Ghz Dual-Core Processor
Nvidia 8400M GS Graphics
2 x 160GB HDDs (320GB)
2GB of DDR2 Ram
The problem happened suddenly one time when turning on, it had been working fine almost all day before that. Things I have tried:
1. Remove RAM modules and test with alternate sticks - no change
2. Remove all RAM - system beeps but no display output
3. Remove both HDDs - no change
4. Remove and reinsert battery after 10 mins, also boot with no battery - no change
5. Remove CMOS battery for 10 mins and reinsert (no main battery) - no change
6. Inspect as much as possible machine for any signs of damage or overheating without complete disassembly - no immediate evidence
Machine had BIOS updated a few months back and has been working perfectly since. In my experience as a PC technician (desktops mainly though!), this would indicate the machine has some sort of mainboard, or less likely, CPU failure. I understand the GPU used is prone to failure but HP claims this is not an affected model.
Also, should it be plain motherboard failure, bearing in mind the machine is 1 and a half years old and had a 1 year warranty, any way to claim since it's clearly not lasted a reasonable amount of time?
Thanks in advance for any help.
2GB of DDR2 Ram
and if it is down to the gpu as others have said is quite common with that model, and if you do have problems there's watchdog on the bbc and trading standards to fall back on
