- 29 Jun 2004
Firstly, recommend me a web browser please!
Anything else I should have on the Bold?
Thanks
Thanks
The weekends at work shouldn't drag on too much now that I have the internet in my pocket!
Opera web browser, works better than the default browser except for when entering text fields it's a little obtrusive.
Some good apps there I never knew about![]()
Guys slightly off topic but how do you enter a word into the dictionary on the phone?
I keep having to spell the words out manually using each letter. Any ideas??
Which BB you got??..if its a full QWERTY keyboard one ie the Curve or Bold ones then they dont support predicative text...if its the Pearl then it must be somewhere in the settings or options to enable it unless it isnt supported.
I wouldnt know as the Bold i have is my first BB ive had....try asking in crackberry im sure there are people there that wil be able to help you.
It's a Pearl so has predictive text, not fully T9 as it only has two characters to a key but similar. You type a letter and it brings up suggestions, normally you'd scroll down the suggestions and be able to input the actual word at the bottom but on this phone there seems to be no where to actual input words you want to use in the future.
Isn't that just a 2kb jar file mate? Shouldn't there be more files? I tried downloading it and it just said install failed..?
