i think that in raid 0 the access time will be the access time of 1 drive rather than sum, as they are being short-stroked this would be less than the standard access time as it is only use part of the drive and not all of it, which would also not limit the 2tb thing as you would only be using about 250gb of each drive giving 1tb of space, also i would be using these on a sas raid card so wouldnt be a problem of 2tb.
Regards Sam
Regards Sam
Short-stroking... I read about this a while ago. I still don't see the point when you could get the same effect just by creating a small OS partition at the start of the drive, without losing most of your disk space.
