Looks like barrel distortion from the lens. It was taken with a K850i so if that's anything like my W810i it'll suffer a bit.
TBH my hoojum looked the same when i photographed it up close.
gt
Cant beat the K850i
gt
I know!Cant beat the K850i![]()
Is the CPU cooler presently causing problems?
I'd possibly place the power connector on the underside of the HDD tray and move the whole tray up by one slot if you are able. This should allow for better airflow over the CPU cooler.
GPU looks great - hopefully the PSU will manage. Going by wattage alone i'd say it should just work - i'd worry a touch about what amp rating the 12v rail has.
gt
is the Zotac 9300ITX capable of playing blu rays via the hdmi at 1080p![]()
Did you get your HyperX ram running at CAS4 in the end?Yep the onboard more than copes with 1080p
Ooh Super, thanks for testing it out for me, looks like I'll be investing in some of that Kingston HyperX then!![]()
