Nvidia 186.18 with new Nvidia system tools (Overclocking)
24 Jun 2004
I have just installed the new Nvidia driver version 186.18, and also I noticed there is a new "Nvidia Sytem Tools" which I have also installed.
Looks like Nvidia finally let you use there special program to manually overclock your card. Unfortunatly there is no auto-overclocking option (what a surprise) so I used the overclock that Tweaktown managed with there Gainward card.
Hopefully it will now play even better in all the games that I currently have installed, even though my system can pretty much do that already.
Has anyone else noticed this software, and have also had a crack at overclocking there cards?
So where is the tool then because I've had those drivers installed since release nd such a tool is nowhere to be seen.
im wondering if this oc software is just for the 200series cards as the op has one. i have a 8800gtx
edit: oh right so its called system tools, a seperate piece of software must be because its not bundled with the latest drivers frm nvid site
Or how about EVGA Precision which runs on Riva Code but much more compatible.
If I`m right in thinking Nvidia System Tools was initially for Nvidia Motherboards.
Ntune is the program to install for Performance option in Nvidia Drivers. I had this installed with pre 186 drivers but on the latest drivers if I install Ntune when I click on Performance tab in NVidia Control Panel it blue screens with oclx64.dll or some similiar named dll.
However as RivaTuner doesn't work with latest drivers for me I used EVGA Precision which is championed by many on here and it works fine.
[timko];14358780 said:
I obviously don't read this GFX section enough as I never heard of this program until this thread. Sounds great since it runs on most brands and not just EVGA :)
Surprised you've not seen it in other threads!
It runs on any compatible card (regardless of brand) and almost all cards are supported :p
Where Rivatuner failed for me on Vista64 at keeping the OC after a reboot EVGA Precision works wonderfully and at the same time offers some nice logging graphs.
Just a surprise that Nvidia gives you the option to manually overclock the card. Just waiting for Rivatuner to finally have a new version to support the latest Nvidia drivers, as they had a very easy to use "automatic overclocking" where all of the hard work is done for you. As far as I can see, there is no overclocking software that has this feature, as the EVGA Precision, System Tools etc only have the manual option
I only get a message that the drivers are not supported but after that Rivatuner still loads and still allows overclocking and manual fan speed adjustment :confused:
Same here but that might be because I use it with an 8800GT. Is it possible it doesn't work with the GTX 2xx range?
