Actually the NEC uses a VA panel...
So does the Dell...
One NEC 24WMGX3 in stock on b - grade for £314.
http://www.overclockers.co.uk/showproduct.php?prodid=BG-020-NE&groupid=595&catid=670&subcat=
Greb it quick, it won't be there long.............
Indeed it won't... need to move fast![]()
Did you get it as its now gone?
Yes Overclockers have made a big cut to the Dell, however I'd still go for the HP with the H-IPS panel - you can't get better colour accuracy and crisp text.Well now the Dell is even cheaper than the HP!lol.
