^thisMulti-monitor taskbar support - surely they can do something better than UltraMon/DisplayFusion.
People moan that multi-monitor is a bit counter-intuitive and I blame it all on this! Come ooooooooooooooooooooon!
microsoft not providing a central 'update service' for 3rd party applications
Mine is only with Winows Seven. I hate the fact that you cannot use, Windows key + E to get to my computer. It now takes you to some stupid directory, documents I think. Sigh...![]()
Just press Ctrl+C with the dialog box focused.-Popup dialogs where you can't copy and paste the text directly (and sometimes they don't even show in eventvwr) so you have to type them out manually or take a screenshot.
selecting all the contents in a folder no longer shows you the combined file size (vista onwards)
In windows 7, WLM doesn't sit in the systray like a good application, and its stacked all my chats into one little icon! I'm perfectly happy how it is in vista.
What I find annoying are two identical machines, use the same media to install Windows, one might take all day and never work quite right, the other could be finshed in a couple of hours and be perfect.
msconfig and other non-resizable windows.
delete too close to rename.
