- 27 Jul 2005
- The Orion Spur
Becuase tbh I think that is a bargain, I purchased a 'Primo Basic' system with a 4850 for £322inc when it was on offer a couple of weeks ago, I had a problem with the gpu and OcUK swapped the 4850 for the 9800gt eco at no extra cost, I purchased the system for my mum and younger brothers and I have to say it's been been running beautifully over the last couple of days, so well in fact that I'm now considering upgrading my ageing secondary system.
As the 'Primo Basic' system has gone up in price now I thought I'd see if I could do any better speccing up a system using the Asus Vintage Barebones systems instead and buying the extra components separately, and it turns out it works out even cheaper doing it that way so I thought I'd make you guys aware of the above spec becuase for the price I think it's a bargain, I was a little worried about the PSU but I've been testing my mums system with the same GPU running Crysis and it running rock solid, the GeForce 9800 GT Eco doesn't even require any extra internal 6pin power PCI-E power cables, it's just powered straight from the PCI-E slot.
, sadly there doesn't seem to be many cheap Intel gaming rigs about.
