Can you get out the room?
I give in. I've clicked the floor next to the suitcase about 200 times whilst having the gold bar selected. Nothing happens :(
are the codes different?
on my laser pen I have 37R55LXXR37L and my little note thing says XX = 24
so starting at 0 I go to -23, then to 18, then to -56, then to 31.
Nothing, did it the other way round as well, nothing.
No mate, you go to the numbers listed. The L/R are the directions you turn to get there.
go out to the main zoom again, so you can see the briefcase, then click the corner to the right (corner of room/floor)
How do you open the test tube?
Witht he knife. Open it up, and click on it, until you get the right tool to open it. ;)
Put the gold bar on the floor, cut the string with the knife, remove bar and a piece of the floor. ;)
With the screwdriver.
Okay, you need to know how safe locks work. So for your code:
37 Right, 55 Left, 24 Right 37 Left
Right/Left is which way you turn the dial and you cannot turn it the same direction twice.
Bledd: Without sound you cannot finish the game.
You're wrong (or unclear on what you're saying). You need to turn to those numbers not that amount of times.
the intrustions inside the sound box tell me how to get the batteries but i can't find a magnet...thought it was the speaker? got some dumb washer though
argh that's annoying it has to be a certain part of it...got them
can someone tell me if i'm barking up the wrong tree please, just used black light on the good luck paper and found a pattern is this anything?
and the back of the panel and the cube.
I cant figure it out though, does it require a knowledge of how to play the piano?
