- 29 Sep 2004
- Newcastle upon Tyne
How do you open the test tube?
echoing my question above, do you need sound for this game?
are the codes different?
on my laser pen I have 37R55LXXR37L and my little note thing says XX = 24
so starting at 0 I go to -23, then to 18, then to -56, then to 31.
Nothing, did it the other way round as well, nothing.
I give in. I've clicked the floor next to the suitcase about 200 times whilst having the gold bar selected. Nothing happens![]()
Witht he knife. Open it up, and click on it, until you get the right tool to open it.How do you open the test tube?
edit
Okay, you need to know how safe locks work. So for your code:
37 Right, 55 Left, 24 Right 37 Left
Right/Left is which way you turn the dial and you cannot turn it the same direction twice.
Bledd: Without sound you cannot finish the game.
the intrustions inside the sound box tell me how to get the batteries but i can't find a magnet...thought it was the speaker? got some dumb washer though
can someone tell me if i'm barking up the wrong tree please, just used black light on the good luck paper and found a pattern is this anything?
and the back of the panel and the cube.
I cant figure it out though, does it require a knowledge of how to play the piano?
