Can you get out the room?
Cheers guys, stuck on the porthole type thing behind the photo frame now - did you work all this out without any help!?
Right this is now jsut ******* me off now.
On the bit of paper i have
1.c1
2.a2
3.c2
4.d1
On my good luck sheet it has
a line going from the G up along and down to the D and then from the L along to the K and an x in the middle
Good
Luck
I also have
GO=B1
OD=A3
LU=B4
CK=d1
Whats my darn code.
I have read this forum through and through and still cant get it
1.c1
2.a2
3.c2
4.d1
Good
Luck
I also have
GO=B1
OD=A3
LU=B4
CK=d1
Whats my darn code.
B3
B1
C1
A4
add them with the other codes
When you say B1 is that along on so from bottom left i would move along one n turn green?
you have to squint a bit ( i did!) but you can see the numbers and digits,
think the numbers are up the side and the letters are along the bottom, but dont quote me on that!
you will have 8 grid references, click each one and then it opens
4 from the paper and four given to you above :)
Nah in the great words of **** it im giving up its just getting on my Nerves now, tried it and still not working
Going on the code provided here i should have
A4 X X X
X B3 X X
X X X X
X B1C1 X
And on my bit paper it has
XXXD1
XXXX
A2XC2X
XXC1X
