- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Linksys by Cisco WRT54GL 54Mbps Open Source Wireless G Cable Router
The Linksys Wireless-G Broadband Router is really three devices in one box. First, there's the Wireless Access Point, which lets you connect both screaming fast Wireless-G (54Mbps) and Wireless-B (11Mbps) devices to the network. There's also a built-in 4-port full-duplex 10/100 Switch to connect your wired-Ethernet devices together. Connect four PCs directly, or attach more hubs and switches to create as big a network as you need. Finally, the Router function ties it all together and lets your whole network share a high-speed cable or DSL Internet connection.
The WRT54GL Wireless Router’s open source code enables router customisation to create firmware for specialised applications or increased throughput. Linux developers and technical enthusiasts can tweak the source code to build in support for applications, either to add extra functionality previously unavailable or prioritise traffic to improve throughput to a given application.
- All-in-one Internet-sharing Router, 4-port Switch, and 54Mbps Wireless-G (802.11g) Access Point
- Shares a single Internet connection and other resources with Ethernet wired and Wireless-G and -B devices
- Push button setup feature makes wireless configuration secure and simple
- High security: TKIP and AES encryption, wireless MAC address filtering, powerful SPI firewall
BUY NOW for only £38.98 inc VAT.
- ~£120, or
