A quarter of A4
  • Thread starter Thread starter 4p
  • Start date Start date
Depends how you quarter it. You probably meant the usual way, which is A6 (as above). You could also fold it horizontally, or vertically, or into triangles, none of which are A6.
[/pedant] :p :)
[/pedant] :p :)
But have the same area as A6 ;)
I was just about to quote the same link to use against you. :p
You are not correct. Check the numbers again (bear in mind the orientation of the paper).
Edit: I take that back - we're both right - see below.
A2 is double the length and width of A4, and A3 is double the area of A4.
There we go, pedantry over.
If there was an image on the paper then you would need to reduce both the horizontal and vertical axis by equal amounts otherwise you will distort the image (no rotating the paper 90 degrees won't work)
So trust me the correct answer to the question "What is 1/4 the size of A4?" is A8
