When you fill it up you wont end up with fuel all over your hands. Seriously, if i have to use a diesel pump, there always manages to be some on the handle of the pump...
I'll go against the grain here and say I tend to find a diesel needs more gas to pull away due to the tragic lack of torque off-boost. In the petrol you will be able to drive it normally without flooring it just to make it move![]()
Not what I've found at all. Most diesels I've been in you don't even need to use the accelerator in 1st, simply release clutch and slot into 2nd at least for normal driving anyway.
Don't put petrol in a diesel car or vice versa as it'll make a right hash of the engine.
As with any 'other car' the only difference is the clutch's biting point etc
in my super old Polo (first car), you could start the engine with the car in first and not even use the clutch, it would just chug and start rolling
what kind of diesels have you driven? if they're all turbo diesels, then the power delivery will feel a fair bit more responsive
