- 24 Apr 2007
- Southport
It seems the join/weld between the arm that goes to the slave cylinder and the shaft into the gearbox has sheared, causing the slave cylinder to pop apart.
Pics:
Is it time to get it towed in? Absolutely gutted.
Where the arm meets the shaft into the bellhousing, the metal is bent and there is a clean shear on one side of the weld.
Anyone have any idea what happened?`
Pics:
