Unless it's snowing, you'll be fine. If it is you'll be knacked.
...only thing was, I wasn't at all sure I would ever get up it.I had a 240bhp MX5 and had the pedal to the metal all the time, even round corners and even in the wet, and I'm not dead - so I'm sure you'll be fine.They handle well, slide nicely, pull out of junctions sideways and are predictable.
You necessarily become a driving god - FACT.
Was coming off a slip road in 3rd accellerating hard on a gentle left and felt the rear end start to break away at 75mph, its not fun at all.Why? Do rwd cars just explode in the snow or something?
Drive according to the conditions and you'll be fine.
Is it a noticeably different driving experience?
Snip
This is something I'm pretty paranoid about for when I get my next car as it A) be RWD and b) be a very expensive bit of kit to replace if I broked it![]()
Im so used to keeping the power down in corners I think id find myself in a hedge.
but best to realise the difference as soon as possible, you should not drive it 'blindly'[TW]Fox;14493672 said:Given your absolutely disasterous car history with regards to driving into things, being 'stolen' by your brother, falling apart and generally chavving about are you really sure thats entirely sensible?![]()
- Plus its ages off yet, lots of pennies to save!You drive that MG like you've just nicked it from a council estate![]()
If one wheel hits a white line at full throttle you can run into problems.
O'RLY
/e-peen off![]()
