***OFFICAL*** Left 4 Dead Thread!
Not played L4D since the week it came out but went on it again last night so bear with me if I'm slow. Does anyone play it with everything on high? For some reason it is more demanding than even Crysis and sends my PC overheating. It's relatively high spec'd but seems it can't handle L4D with high settings... :confused:
:confused:
I've never had a problem with it overheating personally. Try verifying your game cache and putting the settings down to medium. One setting you may also want to think about is to change the page pool memory to medium. Also try setting video options to borderless window mode if the game is crashing with recurring sound...
:confused:
I have everything on 'Low/Medium' now and my GTX280 is still overheating to about 80C :(.
Meh.
i run most settings on high no problem with my spec, but i do disable the AA and lower the texture filtering to trilinear :) hope that helps
get some more case fans..
in and out fans are important
lol. I have 7 fans already...
My L4D is having framerate issues since the new update, used to run smooth as silk. I checked the settings and they were the same pre update .
Anyone else had this?
My graphics drivers are up to date.
.:: New Ocuk L4D Server ::.
In order to support the ever growing numbers of people wanting games, I thought I would contribute to the community by providing an additional server for us to use. For now this is a single server capable of hosting L4D games.
Server Details
Name: Ocuk 7 - Defrag's Server
IP: 85.234.148.52:27025
Search Key: Ocuk
If you are an admin on any of the other servers, you are an admin on this one as well. All the CEVO Config files are uploaded and tested, including Links updated one for 26th/27th July 2009.
For those wanting to use the server, in the normal manner connect from the lobby either typing into the console "sv_search_key ocuk" (without the quotes) should get you any ocuk server or "ms_force_dedicated_server 85.234.148.52:27025" (again, without the quotes).
It is a public server, but if we want it and people are playing on it they can be gently persuaded to move along :)
Feel free to connect as much as you like. :)
A special thanks goes to Link for his assistance and help getting this server up and running and his top tips will come in very handy, something about banning a player called Kearney..... :D
If there are any issues, Myself, Link or Frenchtart (Aekeron) should be able to assist so post on here for help.
For the other Server Admins, I have a MOTD and HOST file I created which you are more than welcome to use. I know Link used the MOTD file with his own HOST page, but I do have HOST web files for Ocuk 1 through 7.
Enjoy!
