Think ilyndix needs to re-think their strategy. If the gskill falcon can go down to £130 then they'd sell a lot of those.
iiyndix sell controllers, they have nothing to do with the price of nand flash chips and thats 90% of the cost of these drives.
intel are more competitive as for a similar waifer size they can now produce almost double the amount of chips. Their downfall is that they produce on a far smaller scale than the likes of Samsung. However a double density production, even in far lower quantities, is still very cheap.
OCZ drives might not be massively competitive in cost even after the price drop, but the new mem chip's, which will no doubt be the cause of a new revision of Vertex's sometime at the end of the year, will drop in a price heavily.
The 60gb drive is also the least competitively priced of the lot, and its not because the controller/drives cost loads, some but not that much difference. Its simply because, they can get away with it. £25 to some isn't anything, to others, its more difference than they can afford. If you can still sell loads at £150, why sell at £100?
Also for those that argue the Intel will only be £25 more for more performance and more capacity, the 120gb vertex is only another further £25 over that, for significantly more capacity. £200 wouldn't be bad, now the exchange rate is up somewhat.
Now assuming 80-90% of the cost is in the chips, and the new ones provide roughly double the amount of chips per waifer, assuming they had similar yields(they won't yet) and assuming they won't increase their profit margin for a while(they will) then you'd be looking at costs dropping to £110-120 for the 120gb Vertex's. Unfortunately samsung and co will only reduce chip prices a little, till they really swing into gear in terms of production at which point we should see some truly great prices starting to approach £1/1gb.
