- 22 Mar 2009
After 2 hours full load on prime95 as the temperature never went above 66C for overclock 4GHz using 4 cores, 4 threads with lower vcore at 1.184v with a push-pull fans of 1371rpm and 1369rpm. I use 21.0x, 191MHz and 4011MHz using intel turbo boost enabled and set extreme performance enabled as well. With a two x Noctua NH-U12P fans with a Prolimatech Megahalems Performance CPU Cooler with MX-2 thermal paste. You can even see there is a 100% full load not 99.5% but a maximum of 100% full load at all time for 2 hours.
I am happy with this result without any crash. I am going to try to get HT enabled now with all same setting to see what the temperature is like after 2 hours.
Hope it won't crash with HT enabled on.
