I had now set myself a new record of the most amazing lowest temperature I ever seen in my life with lower my vcore a one drop below and change a few setting in bios. I had ran linux and IBT all success overnight and again ran prime95 for 2 hours with 4GHz with all cores, all threads with HT enabled with Turbo mode enabled with extreme performance enabled with a crazy vcore set at 1.168v to 1.17v with amazing temperature of just below 70C !!! Look at motherboard drop to 30C, North Bridge drop to 40C, CPU temp drop to 43C and the push pull fans still on low speed of 1350/1342 RPM with all fans at the Antec 1200 case set to LOW speed. I playing some gaming and still stable !!!
I had also replaced two fans of Akasa Apache IP54 with superb s-flow with a push pull on the cpu cooler.
Here is the photo of 4GHz with 70C with aircooled pc with HT enabled 4 cores/8 threads.
