What engine does he have in it?
I'm guessing it's a 2.7/2.8 as the 2.5 doesn't like to go much above 200bhp without serious work IIRC.
the 2.5 is 195bhp ish as standard anyway (24v m50). the 2.8 is a few bhp more, the alloy block 2.8 from the e36 era
m50 manifold and throttle body going on the 2.8 lump (not sure on the code for the 2.8)
even with the m50 and a really bodged manifold it was a bit of a rocket. its layed up at the moment, MS and loom being built
Part of me keeps thinking an old bimmer stripped out would be a right laugh.
It would be, it would also be cheap to buy and run.![]()
I'll let you know when I finish mine![]()
! What have you gone for?It would be, it would also be cheap to buy and run.![]()
I just think there always a risk with cars you have made faster and better to keep throwing money at it to make it more faster and more better, meaning you end up spending loads on what was meant to be a cheap laugh. Its why im more keen on buying something more expensive that requires little modding, and has can have somebody else service it. More expensive, yes, but Im lazy
Or, if it's going on track, less on purchase more on running. Driving a 15 year old car everywhere at 11/10ths will result in all sorts of issues you need to fix.
Every car has an inbuilt amount of compromise. Removing it costs money on top of the purchase price so you might find you're better off spending less on the purchase price and more on the modding.
But if you dont have the ocnfidence in your own skills to do the modding, then may aswell spend that on the purchase price.
But this is just me. I do wish I had the skills or the patience to learn the skills to do something myself.
325 touring. Nothing fancy, just undoing as much of the old-ness from the car as possible.
Replaced all of the rubber bushes with bmw parts.
Serviced the boat anchor properly and changed all of the consumables.
"chipped" the ECU, lol.
New shocks and spings. Nothing fancy just budget items with a 35-40mm drop.
New discs/pads all round.
Braided brake lines.
New M3 lollipop bushes.
. Done a bit of polybushing, stripping and gone for bigger wheels (for better tyre choices).Take things easy mate.
Most modding is basic and bolt on. That's enough for you to have a whale of a time on track. It's only when you want to compete that you need to really get technical. Just choose a car and join the owners club forum. Whatever you're gonna do, someone will have already done.
Plus, drivers tend to try harder when their car is worth less than a fortune.
