S-IPS OR H-IPS how to tell
6 Apr 2009
Liverpool
which panel i have in my HP LP2475w apparently the h-ips is better panel so wondered if there was anyway i could check thanks
The monitor menu says F/W GIG 068 but on the box it says REV GIG 143.
Is there a way to upgrade the firmware ?
MW
TFT Central were saying that this monitored had a H-IPS panel back in September last year. Perhaps this new revision is just firmware tweaks for input lag etc?
I'd say it's pretty safe to say you have the newer H-IPS panel :)
Are you using the default display settings ?
MW
