DGTeam Firmware Sync Rate
24 Jun 2007
Landan.
I'm trying to implement the network shown in this thread (though things have moved on since then), and want to use the DG834G as a simple modem that feeds my Linksys WRT54GL (with DD-WRT installed).
Everything works great, however the Netgear only syncs at 18Mb/800k whereas my O2 box syncs at 22Mb/1.3Mb.
Does anyone know anything I can try to attain a higher sync speed? Or is the Netgear just too old now? It's a v2 btw :)
I'm using the following settings:
* Encapsulation: RFC1483 Bridged
* Multiplexing: LLC
* QOS Type: UBR
* Autodetect: Disable
* VPI: 0
* VCI: 101
* DSL Modulation: ADSL2+
* MTU: Manual
* MTU Size: 1500
(Shamelessly stolen from someone else)
Alternatively, does anyone know how I can get the O2 router to just work as a modem?
Thanks in advance
Yes you can use the O2 box as a modem but you might as well look for a Sky DG834GT. The DG834G v2 uses a chipset that doesn't work so well with Be/O2 so synchs won't be so good.
Here's another method to get your O2 box into bridge mode if you don't get on with the first one. Also allows you to patch a cable back into a spare port on the O2 box for webadmin access, which that Bridge.ini isn't configured for.
Cheers for all your help guys - worked like a charm :D
One thing to note for anyone else trying it is that you should hard-reset the router back to its original config. I'd been using it with a static IP and so the instructions given didn't initially work.
Thanks again :)
