Your info is a bit dated - well aside from the fact SLI motherboards are crap coz thats still true.
I think yours is biased
In a properly setup system with decent drivers you shouldn't get microstutter however.
on Call of Duty® World at War is there a 91fps limit??
Micro stutter.. never noticed it myself
it happens when your fps are around 30-40 apparently (i'm not sure if this is 100% correct or not) from what i've been reading recently, it makes you perceive lower fps than it actually is. So as long as you are getting over 60 (which will be very difficult at high resolution anyway) you would be fine.
Bit disappointing since it's hard to maintain a high FPS on new titles especially at high resolutions, but as long as you don't go crazy high i would have thought it would be fine.
It would be worse with low fps but I thought you could get microstutter even with high fps. This is what worries me, where dual-gpus sometimes produce larger intervals in between the individual frames:
http://www.pcgameshardware.de/aid,631668/Video-proof-Micro-stuttering-may-destroy-the-performance-gains-from-current-multi-GPU-technologies/Grafikkarte/Test/
Would you really notice any difference if the fps was above 90?
That article is quite out of date and somewhat more off putting than it should be, i don't have the links to hand but after recently skiving at work reading everything i could regarding micro stutter the new generation dual GPU's/doubled up GPU's aren't as bad. The 3870X2 was a lot worse by comparison in such articles.
It does exist though, i believe the general conensus is that if frames are high enough and stable enough you shouldn't notice a thing.
For what it's worth, as picky, fussy and anal as i am about things i'm taking the plunge soon with a GTX295.
if u have a monitor thats running at 100hz and playing action games then yesWould you really notice any difference if the fps was above 90?
