 - 26 Aug 2004
 - South Wales
Why isn't there a product like a koolance exos but doesn't suck?
Well, as far as I can see, this thing will last me forever.
But then I'm the man who, when he specced his new house, built it with just not a CAT6 loop, but also a water cooling system for the PCs that heats the garage@self
And not a little bit sad.![]()
at some point before mid next year i will be able to afford a MM u2 ufo case, how long do people usually keep this? i mean is it a full time keeper for any build?
is it possible to get these with watercooling prefitted or is it going to cost more than it's worth?
might just do it, cant help but feel it might be more of a novelty though which would then turn out to be a big waste
just have to decide if it's worth the money or not. not to mention upkeep of it which would be more £
Great cases but you have to ask yourself whether you could live with somethig so big? And I'd go with custom watercooling.
Well like most people i don't move my case around so i don't think that's such a problem. Unless the case is a pain to get into once everything is fitted?
I was wondering if they can be prefitted with custom watercooling, if i was spending that much i wouldn't skimp on that![]()
better to have 2 x 120.3's maybe? i thought one for the CPU and one for a dual GPU or 2 GPU's.
Also is everything you can get used just as good as when it was new?
are there any other good but cheaper cases than the mm ufo that can hold 2 120.3's?
They come to your specification, but the standard ones are drilled to take a PA120.3 at the 'front' and a PA120.2 at the 'back'. But you can also get combinations. The 120mm port under the drive rack at the front is big enough to get a PA160 in without any modification or you could have 10 PA120.1's if you wanted.
One possible snag though. The new Thermochill rads have 15mm fan spacing instead of the old 27.5mm.
You guys think it might be worth watercooling the CPU with a dual radiator, then just buying aftermarket air coolers for the GPU? all i want to do is lower temps and make it quieter.. that alone should make a big difference?
I'm not sure, but that would definately be easier.
