Brake pads are not hard to check.
Her car was up for a fail on a blown side repeater and I warned the guy that he wasn't going to fail it and he was going to put a new bulb in. They charged me £5 for the bulb![]()
Leon checked the CV boot when he fitted the coilovers. It was fine when he checked it but must have fail0red before the MOTNot had a failure yet, but it would have failed had i not given it a good look over and sorted the following!
cv boot, lower arm bushes, arb link and a hole in the exhaust.
Everything an MOT inspector will happily fail it on without batting a eyelid!
Otherwise it would have passed
Bah! I had planned on changing them soon though anyway so I guess that saved a bit of effort one way or another seeing as I got a decent set for a decent price anyway! Also it failed on the seatbelt being slightly frayed, and they even noted my Magic Tree! Me thinks they were a bit anal..
Indeed, I checked all the other lights including brake lights and indicators, just forgot to do the numberplate lights, but I always remember now.Probably worth checking these things before you take it for the test guys![]()
Leon checked the CV boot when he fitted the coilovers. It was fine when he checked it but must have fail0red before the MOTOtherwise it would have passed
1) Passenger side front tyre worn (this is obvious and will be replaced), I think the driver side looks abit iffy but the tyre place i went to said it looks ok.
Define "a bit of acceleration".2) Handbrake issue - I had my back disks and pads changed about a month or two ago and the guy didn't do something right as the handbrake is not working effectively, when pulled up its enough to stop it rolling down a hill, but put abit of acceleration on and it moves.
