- 15 Aug 2006
- Leicester UK
It's not difficult to get the pushchair in a 5 or a 3. The focus was tight but it went it eventually. The problem is not the access to the boot, it's the boot itself. It just doesn't go far enough back. The pushchair is 110mm long when folded. I'll take the measurements of Dad's when I see him next, but from the back of the seat to the inside edge of the boot is less than that.[TW]Fox;14692460 said:I think you actually need to look at some cars - the boot on a Mondeo/Octavia/Mazda6 hatchback is not like that on a Golf or a Focus - it's basically the same as the boot on a Passat but with a MUCH bigger more practical opening.
I drive a saloon and the boot is huge but you cant fit anything through the opening making the size irrelevent.
A passat will be limited due to the way a sallon boot opens, why dont you just have a look at a Mondeo, or Mazda 6, or Toyota Avensis hatch, and see what we mean.
With those types of hatchbacks it doesnt matter how much stuff you put in the boot, as you can remove the parecel shelf, or have it at an angle, you cant with a passat, as the saloon has a "fixed" space. The boot on a mazda 6\ford mondeo etc is massive, and i bet you can fit the pushchair along the front of the boot, and the many suitcases in there too.
I see what you're saying but if I went for an avensis, where the pushchair only goes in diagonally, you would always have to take the parcel shelf out when you went away.
AFAIK you're correct. I've only seen saloons/estates.Isnt the Mazda 6 a saloon only?
