If you want to RAID the 2x1TB drives you'll have to use the "RAID" option in the BIOS, you won't be able to use "IDE", "AHCI" or whatever else it gives you. The good news is that single drives that aren't part of an array are handled by AHCI anyway, so your SSD will work just fine.Hey guys,
I will be building my new PC in a week when I get home. I've just bought a Crucial M225 128Gb SSD which I'll be using as my OS/apps drive. I also will have 2xWD RE3 1Tb drives that I want in RAID mode for games etc.
My motherboard is an Asus Rampage II. I dont know anything about the BIOS setup for the ICH10R controller, and the various options eg SATA/ACHI/RAID that you guys mention.
Would it make sense to:
* Clean install W7, letting W7 configure SSD with no tweaking (Timko's link to MSDN blog seems to infer that W7 will do everything for you, just leave alone). Bios ICH10R controller probably set to SATA?
* Install motherboard drivers and Intel Matrix Storage Manager Controller, which in turn installs the ACHI drivers.
Upon reboot do/should I change the ICH10R controller to anything other than default eg ACHI/Raid, for best performance of SSD bearing in mind the 2 RAIDed WD drives?
Many thanks in advance, good stuff doing the groundwork on getting the SSDs setup, cheers!
I haven't bothered installing the Intel Matrix drivers because of the issues I've heard with people saying Wiper doesn't work with it. Then again I don't even know how relevant Wiper is, whether Win7 is actually handling it behind the scenes, etc.
