Hi all.
I have recently just switched from Vista 64bit to Windows XP 32bit, got fed up of Vista
I installed everything correctly, drivers etc. I boot up CSS and it freezes 5 mins, it doesnt turn off the screen is just frozen and i cant do anything at all. I never had this problem with Vista. I have taken certain RAM modules out to see if that would make any difference but it did not. I have since installed vista again to see if the problem was recent but CSS played fine, so im back to XP now trying to fix this problem, I just do not know what can be causing it.
SPEC:
Mobo: Asus Striker II Extreme DDR3
HDD: WD 500GB
RAM: 4GB Corsair
GFX: 8800GTS
OS: Windows XP Pro SP3 32bit.
Hope someone can help me out so i can solve this issue, its getting so irratating.
Thanks
SPEC:
HDD: WD 500GB
RAM: 4GB Corsair
GFX: 8800GTS
Thanks
