Man of Honour
- 27 Sep 2004
- Glasgow
fists can and do kill people, not sure how likely that is with glass however i can imagine it is significantly less likely then a massive blow to the temple with a fist or elbow
But the attack is unlikely to be done in the same way, a glass is much better as a thrown or stabbing weapon when broken so no, of course you are less likely to get a massive blow to the temple with them.
There IS a downside. Plastic DOES taste awful compared to glass. How can you not taste it?
Can't say I particularly noticed and I spent a good few months drinking out of largely plastic glasses in pubs and nightclubs in Finland. It is possible that for some drinks you'd notice the taste but for a generic lager the difference is negligible at best.
But the weight man! How can you expect me to drink from something so light! without the extra weight the cup will hurtle into my face as my huge Alpha muscles over compensate!
The weight is something I notice though, it's not a major issue but it feels quite distinctly different in hand - not better or worse, just different.
, But they will never have my 2 pint novelty glass
