Help please - Have £4000 but didn't like the ST220
Status
Not open for further replies.
Oh, that's ok then!
Indeed, why you would spend £2 on some secondhand pads, pads that should not be fitted to another set of discs after they have been run in is beyond me, whats a new set of cheap front pads, some basic mintex ones come in around £20.
Hardly worth the risk for £18 imho.
:p
Not on the Octavia you don't.
I'm glad I didn't have to pay labour for my cambelt/waterpump change, parts were about £120.
Thats a cost breakdown on my car which i said i was going to post, i know not "all" items might carry the same labour rates.
I suspect the fitting to a transverse engine will cost around £280 - 300 all in.
£300 sounds about right.
The control arm set-up is totally different on the Octavia. Nowhere near as complicated or costly.
Status
