Man of Honour
- 5 Jun 2003
- Falling...
She makes such a palaver of cooking that egg! :/
Thanks a lot,Do it clean (no weight) first with arms out in front to get the hang of the movement then try with a clean (empty) bar.
Bar should be just down from the neck, on the ridge of muscle that pops out when you rotate your shoulders to be able to hold the bar.
Thanks a lot,
I have dumbbells, should I still hold them beside the neck, or like they do on exrx
http://www.exrx.net/WeightExercises/Quadriceps/DBSquat.html
Thanks RB, to be honest, my thighs aren't quite strong enough yet for me to get down really low with dumbbells. Without I can get down low, I'm just not quite there.
I'm using 2.5 kg per dumbbell, yes I am weak![]()
I held off posting in this thread hoping it would die off.
Surely you have picked up a bag of shopping before?They normally weigh well over 2.5 kgs so i guess it must be a mind thing
