oops! didn't do that. Is it really that recommendable to do that?
Personally I don't think it's necessary and absolutely not worth the hassle of installing everything again.
The new stacks in grid view really don't suit the 3d glass dock at all, nor the right click options on dock items. Goes very well with the black 2d dock but seems really hotchpotch when using the default.
I have always found at least do one zero out just so OS X runs at it's fastest. I always seemed to get more errors over time if i didn't.
How do you get the black 2d dock?
rp2000
defaults write com.apple.dock no-glass -boolean NO
killall Dock
to get glass dock back
defaults write com.apple.dock no-glass -boolean YES
killall Dock
Doing a single pass zero useful to ensure a drive is perfect (no defects) but it's not required for clean installation. With an SSD you don't want to do any zero initialisation if possible as it will shorten the life of the drive.
You're right, edited my post.T'other way round isn't it?
Stacks definito better with 2d dock
The 3d dock never worked really well imo because of the title bar. The window drop shadows look great and definitely match the 3d dock but then your eyes get to the flat title bar and it just 'breaks' the 3d effect.
Do you need a Microsoft mouse for those drivers to change the acceleration curve?
Is it just my eyes playing tricks on me but my display appears a lot more 'vibrant' than it did with Leopard.
I'm just doing a SuperDuper! to a different hard drive which I'll then remove and store somewhere safe and then I'm just going to let it upgrade my Leopard installation.
All done, just playing now. That really was painless.
