I'm about to order this drive 64GB version....Are the drives being shipped with the latest firmware for trim?
Also After fitting the drive in my laptop...Do I need to do anything other than just install windows 7 pro?
Slightly noobish questions from me I know...![]()
Thanks for the replyDagwood,
Are you comparing against the 128gb/256gb results? The 64gb drives are slower, but I can't remember their numbers (earlier in this thread) but IIRC it looks similar to those.
You shouldn't need to disable superfetch and defrag in Win7, it disables them running on the SSD, but leaves them active on normal HDs which may still benefit.
Do we have any eta for the 64gb version of these drives?
I've been in the warehouse queue for over a week![]()
Strange how the drive would need to be setup to make it run the way it should. Can't they just be installed and then Win 7 put on without any tweaking?
Seriously though if flashing firmware is too much for you then pc's probably aren't for you![]()
Thats why i am a member on here!![]()
Just strange how new hardware needs a flash!! Not as if it is very old. I will stick with mechanical for now. Good thread though. Stopped me from rushing in and spending a lot of money on an SSD!!
