Picked up some cyclones yesterday and they have a fair bit of paint peel etc. I was going to leave it but I couldn't get any wheel bolts today so out of boredom I decided to re-do them in white!
Started with:
Sanded and filler primered (found quite a few minor low spots!)
Primer sanded, see those bits that look like splats of primer? They are in fact low spots! (quite a few around the alloy!)
Now to attack the major problem, the paint peel. I couldn't smooth it off with sanding and didn't fancy spending FOREVER getting the whole thing back to metal... bit of body filler did the trick though!
Sanded back again
Cleaned up and put on first coat of hammerite smooth white!
Second coat
Didn't clean up around the badge enough, rough surface including filler primer left! DOH. At least I know for the next 3! This has since gone with more coats of paint
Missed a MASSIVE chip cannot believe I didn't see it, if you look above it's right next to where I was body fillering! SILLY BOY.
This was about the 5th coat of paint! Alloy 1 done, 3 to go!
Ta
Alec
Started with:
Sanded back again
Second coat
Ta
Alec
