Remove head off PWR SW & RESET SW?
2 Oct 2003
Chester
I'm trying to feed these cables through a hole but the head is stopping it. Can I remove the head and reattach it safely?
I personally would not risk it, very fiddly.
Is there no way you can make the hole a little bigger?
That must be one SMALL hole?!?!
The connectors come off easily with the use of something like a pin. Go back together just as easily.
Yup, look on the back, there's a little bit of plastic you can level up slightly and then pull the contact out.
