- 2 Oct 2003
- Chester
I'm trying to feed these cables through a hole but the head is stopping it. Can I remove the head and reattach it safely?
That must be one SMALL hole?!?!
The connectors come off easily with the use of something like a pin. Go back together just as easily.
This would work but it's far quicker to drill a hole and use a grommit.Cut the cable in half, feed through and solder back together?
