=== Corsair H50 High-Performance CPU Watercooler (Socket LGA775/1366) ===
The Corsair Cooling™ Hydro Series H50 CPU Cooler gives you the power of liquid cooling in a compact, easy-to-install package. You get superior cooling for higher overclocking performance without the complexity of traditional liquid-cooling systems.
Air-based CPU coolers simply aren’t as efficient as water coolers, and can take up too much valuable space. The compact, closed-loop Hydro Series H50 takes your CPU’s temperature to new lows and takes up less room doing it.
- Pre-filled, closed-loop system is easy to install
- Copper CPU cooling plate for maximum cooling performance
- Integrated pump and reservoir is sealed for zero maintenance and improved leakage protection
- Large 120mm radiator for fast heat dispersion
- High-efficiency, low-noise 120mm fan for drawing cool air across the radiator
- Two-year warranty
£59.98 inc VAT
IN STOCK
- Two-year warranty
£59.98 inc VAT
IN STOCK
