The New Cases Gallery
New case is on its way.. and then it needs to be modded. temp home for my gear.
StevenG
My build... finally
Finally put some photos up of my setup. The desk is in a bit of a state, need a new one not to mention a larger room as I want 3 24" monitors at some stage.
I thought I would add some pics of my setup here just for the hell of it..
I got my TJ10 nvidia edition case at the start of this year.
If I knew then what I know now, I would have gotten a different case, as the TJ10 isn't very good for cable management at all, there are no holes in the mobo tray at all, and there is about 1 1/2cm between the mobo tray and side panel, so it is really tricky getting the panel back on again once you have ran cables between them.
However, I will be sending my case off to a competitor to have some cable management holes cut into the mobo tray, I will also be getting the roof modded to take a 120.3 rad for my upcoming custom loop, and I will be getting all the internals powder coated in red to at the same time, I should have this completed within the next few months.
Anyway, enough chit chat, and on with the pics!
I can't wait to get the case modded and get my custom loop setup, I have got most of my WC parts already, I just need to get my CPU block (HK 3 Copper) and my fittings..
http://lh3.ggpht.com/_SXlzNIVW_qI/SqLC6kriIgI/AAAAAAAAAgg/cPAZ78aaXOM/s800/04092009417.jpg[IMG]
[IMG]http://lh5.ggpht.com/_SXlzNIVW_qI/SqLSIdHN0nI/AAAAAAAAAgs/Kc5JFwuDJv4/s800/IMG_3359.JPG[IMG]
[IMG]http://lh6.ggpht.com/_SXlzNIVW_qI/SqLSI-w0QnI/AAAAAAAAAgw/x2DpDpL8vDI/s800/IMG_3392.JPG[IMG]
[IMG]http://lh3.ggpht.com/_SXlzNIVW_qI/SqLSJF5klgI/AAAAAAAAAg0/Z2oMykFhU8Y/s800/IMG_3396.JPG[IMG]
Still a bit of a work in progress...[/QUOTE]
Thats a cracking setup, so spacious in that case! Guessing the new obsidian was a breeze to build in?
http://lh3.ggpht.com/_SXlzNIVW_qI/SqLC6kriIgI/AAAAAAAAAgg/cPAZ78aaXOM/s800/04092009417.jpg[MG]
[IMG]http://lh5.ggpht.com/_SXlzNIVW_qI/SqLSIdHN0nI/AAAAAAAAAgs/Kc5JFwuDJv4/s800/IMG_3359.JPG/IMG]
Sorry but, with them cables braided like that make the case look so messy. :(
