I <3 Americans
Well, that is just ridiculous.
And also, how freakishly tall does Clarkson seem in that vid!?
I think that's a bit of a fix there, most Americans know where London is, however where England actually is on a map...:p
He is around 6'6, makes me think James May is over 6' as well, which explains why Hammond always looks so small.:p
If a truck was carrying birds (all seated on perches), and they all took off at the same time inside the truck, would it get lighter? :p
No, they would have to exert an equal or greater downward force to gain lift.
Newtons third law, bitch :p
Correct, Mythbusters did a great episode on it.
Once they are air borne the lift generated by the wings flapping does not all necessarily result in a downwards force on the bottom of the truck bed surely .. unless it is an air tight container without any other eddy currents inside.
The truck or the force of the truck on the road.;)
I stil can't believe that after thinking it over (as it is essentially one of those questions, similar to the "what do cows drink?" ones) people still don't believe that a plane can take off on a conveyor belt...
This video is a bit long but it's very car-crash-like...
Americans. Religious Americans. Does it get any better than this?
"She's Indian. It's like an African country in Asia. Do you consider yourself Asian or African?"
