Coke Spillage :(
Funny I managed to do the same a couple of years ago. My case had broke so I was running the computer ontop of it's motherboard box, I was intending to replace the whole system in a couple of days so wasn't that bothered about it getting damaged.
Anyway managed to knock a whole can of coke (regular) whilst gaming. Obviously being outside the case it got drenched, sparks flew, the screen went funky that sort of thing.
Removed the power, it wouldn't turn on. Left it for a few hours to dry and worked absolutely fine. Still runs to this day.....albeit now in a case ;)
On the computer itself, not the keyboard? More fool you. I see this with laptops occasionally, and can understand that. Doing it to a desktop defies belief.
You have to keep it turned off. Strip it down completely, wash everything with distilled water. Cola is acidic, it'll destroy everything if not washed off. Leave it to dry for 3 or 4 days. Reassemble and hope for some of it to function.
Likely is that the board shorted and killed anything attached to it. Shame on you for pouring cola into your computer. That you then, knowing it was covered in cola, actually turned it on again means in my eyes you deserve the dead hardware.
Just reread your post. You've left it covered in cola, which is eating the circuitry. You tried to turn it on again, and had it running when the initial accident occurred. It's dead. Give it a nice funeral service and treat the replacement better.
Have to admit that I moved my tower out of spilling range the other month to prevent an incident like this happening...
Unfortunately, Jonj’s prognosis of your system's probable demise is right.
I’m afraid your pc is probably toast - although you may have some salvageable parts but I wouldn’t want to test them in a working machine – catch 22.
You were unlucky(sic) that the machine was on when it spilled and unfortunate, in the fact, that you didn’t realise that you need to strip the rig down and clean it then let dry thoroughly (week minimum) before reassembling and switching it on.
If it’s any consolation there is a good chance that it fried with the initial spillage – and the error in turning it back on so soon (without cleaning) probably just added insult to an already dead system.
You will have to chalk this one up to experience.
How did the coke actually get into the PC? Were you running it out of the case or with the side panel off? Or did it get in through the top fan grille or something? Otherwise, with most cases, I can't see how that much coke would find its way in, unless you were really clumsy or really unfortunate.
(edit) I see from another thread that you have the P182. I'm guessing it went straight through the top grille. In that case the graphics card is almost certainly toast, along with the mobo. Unfortunately the 120mm fan has probably redistributed the coke pretty much everywhere... was the PSU fan pointing up or down?
Coke is a real computer killer
Insurance?
If not:
If it is still wet (probably not ) switch all power off and take it apart as much as you can and rinse it all with warm water
I know this sounds insane but some damage has been done, coke left in / on circuitry will eat away at it so if you can clean it off
Dry all the part thoroughly at least 3 days, put it back together and power it up with your figures crossed
Belive me there is not much you can do. I have learnt the hard way :eek:
What he said.
And if it still doesn't work, and you've got no other options, I'd WD40 the hard to reach places and try again.
even bottled water is better than coke :p
well my college used to let you have bottled water near the PCs at least
I bet it teaches you a lesson, drink bottled water near PCs :P
Does anyone remember "mecca cola", I saw it sold at some local asian corner shops about 4 or 5 years ago.
I tried it once, it was exceptionally bad, and was produced under a rather hilarious premise.
http://www.binaziz.com/products/meccacola.jpg
you want to try "boga cola" in tunisia, it probably is made form camel dung, worst tasting coke drink you could possibly imagine!
On my pc, I have a little button that activates a cup holder; cleverly, doubles as a DVD player also.
thats my quote of the week right there:p
With my case im probably going to make a frame to stick on the top of my case jsut a skeliton type frame in a triangle to make it impossible to put anthing on the topof my case. Maybe overclockers should some how make these and sell them to those who are crazy enough to put stuff on top of a open top case :D. But i gues its also good i got the corsair 800D its to big to stuff on top off but i will consider putting something on top to remidn me and any1 els not to put anything on top of it to save future OOOO NOOOOS. Like i explained all realy need is some kind of rame to stick on the top that makes it impossible to ballance anything on the top also when ur out if your worrid about kids or any1 els using it as a table maybe if the pc is off cover the top with something.
Ps beware of the elbow (cough) i mean wind yes wind :).
Im sorry that im not computer expert e.t.c, i didn't know that you had to strip it down e.t.c and wait for it to dry for a couple of days, thanks for the advise all, well some of you anyway, as for the others, there's really no need in the childish comments, if you haven't got advise to give, well then i see no point in commenting at all tbh.
The PC itself is covered in my house insurance, which im waiting for a call off them, hopefully it will be sorted soon. Haha, Yer the coke spilled through the top fan of my P182 Case which like you said, would have spilled everywhere e.t.c
Also will i be able to salvage any files that i have on the HDD at all? As ive got some very important documents on there???
GoodBye PC :(
It's quite possible the HDD will be unaffected as the 'circuitry/workings' will have 'hopefully' not had any 'direct' contact with the coke and the sata/power connections, hopefully, will have shielded it from drips.
However, there's still a chance it may have been crippled via the MB/PSU blowing or it may have got drips sprayed on the underside via the gfx fan...
Just check it for residue/sugar - clean if necessary, let it dry for at least a few days - and then test it in a different machine.
