I believe uTorrent limits your download speed if you set a stupidly low upload speed for it, could this be the problem?
This, anything below 6 and it will limit your download.
That's utter stupidness. Makes it useless for private trackers. I usually upload nothing and get 1.6MB/s down with Azureus.
LMAO! Really?
Edit: it's not that I don't want to upload. It's just that the Seed : Peer ratio is soo steep, it's impossible for me to upload. The guys with gigabit connections take care of that.
LMAO! Really?
µTorrent
+1µTorrent
I agree that it's a bad decision. Leeching is bad, but if you want to leech then it should be your decision, not your torrent client's. And you might just want to leech temporarily, when your ratio is actually pretty good.
- 3. What does Download Limited in the status bar mean?
This is an anti-leech protection put in µTorrent. It means your upload cap is set too low, and as such, your download is limited to 6 times that amount (3 in 1.4 build 402, 6 in 1.4.1 build 405+). It's set to 6 times the cap so that legitimate users who need that cap (dial-up, ISDN, certain slow broadband connections) are unaffected by it. It only applies to upload caps of 1-5 KiB/s.
It's really surprising that something like that is hardcoded in to such a high profile client.
Unless this low-upload-cap-limits-download-speed is part of the Bit Torrent protocol, it's pretty bogus for uTorrent to enforce it.
