Most german built engines do moon mileage if treated right, thats not even half a cars economical lifetime 100k.
I'm a vag whore, I purposely look for high milers because you save a ton of dosh, most people don't realise that times have changed and that cars go on for much longer.
And more often than not, low milers have been shagging round town in stop start driving, motorway miles are far less stressful on the engine.
What you save on buying the car, you will save on depreciation anyway.
The engine is just one peice though isnt it. After that kind of miles, and once its probably been through a few owners the car is probably going to be sha$$ed unless its been cared for very very well throughout its life - which to be honest isn't likely to be the case. The interior trim will be worn, the seat bolsters are likely to be a bit saggy, the car is going to feel pretty worn.
I'm lucky in that I can afford to buy the car I want, at a decent spec level and engine choice without needing to go very old. My choice, your choice. And no, I dont drive a 116 lol
