I'll be looking to spend upto £4k-£5k, on the list at the moment are..
- MG ZT
- Mondeo ST220
- Octavia VRs
Personally I'd avoid where possible selling to a friend. For one thing, what do you do if he has engine failure? Chances are that you're left with a scenario of:
1. He makes you feel really bad about buying a car from you that's had problems, and you end up getting involved, probably financially.
2. You ignore it and potentially result in issues with your "friend" relationship.
Avoid it like the plague if you can.
all the same type of car as your ST24, may aswell keep it if your happy with it.
hardly that much of an upgrade, especially at a cost of 3-4k extra.
