The *Official* Eve Online Thread
Mmm, I need to find something different to do in game. I was planning on saving up for a new ship then venturing into lowsec so I can afford to replace my shop if I lose it, but I'm still not sure what I'd actually do in lowsec. I'm thinking about the whole faction warfare instead as a first taste of PvP, is this worth it? I've not done much else in-game besides missions, which is probably why I'm feeling a little burned out.
Looks like now would be a good time to train cloaking :D
Get them T2 special lasers warmed up and waiting at the edge of the belt.
[Proteus, 1 MAR WH TUrrets]
Centum A-Type Medium Armor Repairer
Dark Blood Energized Adaptive Nano Membrane
Armor Explosive Hardener II
Armor EM Hardener II
Magnetic Field Stabilizer II
Capacitor Power Relay II
10MN Afterburner II
Large Capacitor Battery II
Large Peroxide I Capacitor Power Cell
Heavy Neutron Blaster II, Antimatter Charge M
Expanded Probe Launcher I, Core Scanner Probe I
Auxiliary Nano Pump I
Nanobot Accelerator I
Proteus Propulsion - Localized Injectors
Proteus Offensive - Hybrid Propulsion Armature
Proteus Engineering - Power Core Multiplier
Proteus Electronics - Emergent Locus Analyzer
Proteus Defensive - Nanobot Injector
Hammerhead II x5
Hobgoblin II x5
Are you running a grid implant to make that all fit? It's quite strange, eft is telling me I can't fit it due to grid unless I nail in an implant but the 'all V' character can fit it. I can't see which skill is making the difference.
It's showing me 1735/1674.99 for me and 1735/1820.31 if I use All level V
Cou;d it be the Engineering subsystem? Every level will give a 5% power grid increase no? So level 5 will have 25% PG bonus, that might be it?
Question on the setup.
Cap battery over the rechargers?
Tbh i had no idea when i layed the isk down building mine up, pretty much identicle setup aside from using ion's up top, sansha chargers over the batteries, core x actives over the t2's, and ds resistance, and t2 versions of the rigs.
I ask because the caps not so stable. I use this ship for lv2-3 missions, the odd lv4, stable cap would be nice.
Yeah i have that setup on an ishtar, had the feeling it only kinda worked though because all you were doing was running the dual rep and hardners, with a couple of chargers on top of the 2 battery combo.
No cap loss through f1-5 ect.
In truth i hadn't considered it though, when i can get back in the game ill check it out, wifi on this campsite, no p2p... no eve.
That'll be the one. Nice setup btw.
Basically what vader said, the cap batterys provide a lot more recharge than adding cap rechargers would do.
The setup ive posted is fully cap stable with everything running at around 36% iirc dont know how well it would work for lv4s since its using blasters. Then again i dont really do missioning so im not sure.
