Derren Brown posted that link on his blog.
Exactly what I expected (see edit).
hmm:
DERREN Brown predicted those Lottery balls a YEAR ago - but for some reason was too afraid to admit it.
Word reaches me that there was another explanation for his, quite frankly, unbelievable Lotto luck last Wednesday.
While filming an explanation of his trick the next day, he showed a studio audience a piece of film in which a group of kids predicted the six balls.
http://www.thesun.co.uk/sol/homepag...Brown-predicted-Lotto-result-before-Xmas.html
he showed a video of 6 different kids picking out the 6 winning balls, which must have been at xmas because it was on oxford st with xmas decs up. Aside from anything about why it must have been at xmas and not last thursday, what's to stop him having filmed 49 kids picking the numbers 1-49 out of a bag and then splicing together the right ones? It's the weakest, most see through and least entertaining explanation, that's the reason it was cut from the friday show's edit
It obviously isn't authentic though![]()
You've seen it as well, have you? Or are you going to pull the "I don't need to see it" line? It helps to have direct experience of something if you're going to pass judgment on it.
Whatever he shows, it isn't authentic it is impossible to predict the lottery results. It was quite clearly done using the split screen technique as there's been no plausible explanation for the first ball suddenly moving.
Maybe the balls were too tight in the little container so the other 5 balls pushed it up a bit.
Wish this would just die down, he's a con artist nothing more.
Helps but isn't necessary. It's easily possible to state, with strong confidence, that the content of a video is a trick of some kind, if the mathematical chance of it being real is absurdly small.
All by themselves, at just the right moment to fuel a conspiracy theory..? Unlikely. Well... on second thought, it's as likely as predicting the numbers
This.
With a name like Lysander I'd have thought you would've stumbled on various explanations of magic by now, what with one of Derren's tricks being usage of the very-similar-to-your-name Losander tableYou've seen it as well, have you? Or are you going to pull the "I don't need to see it" line? It helps to have direct experience of something if you're going to pass judgment on it.
Do you honestly think Derren is going to say
"Oh noes, you found out it was split screen, I tried to fool you all and now I'm the idiot"
He's more likely to say "pwned."
