The problem is, that if correct, the sources would place the 5850 in the 200-230 range. However, the recent price drops by OCuk have put the GTX285 in that price range too. Although the 5870 will have no competition, the 5850 may have a run for it's money if it's performance is close to that of a GTX285, as it's projected price is actually more than the aforementioned 285. Cat fight!
I'd like a million pounds and a 13" errrrr 'thing'.
I guess one out of two ain't bad![]()
Looking bad for team red with that price. I will be sticking with the 275 for my new windows 7 build next month.
Dont forget that the 5870 is actually only a tad better than the 295
295 = dual card remember, comparing them is ultimately pointless.
Not only is the 5870 still cheaper, it's also a single card, making is better than the 295 by default as it avoids all that dual GPU malarky.
+1More lightly that ATI will milk the cards for a good prifit till the 300s come out tho![]()
Woops, misread the thread title, I think £230 is a bit optomistic, I imagine it will hit £250 after 3-6 months and ATI's prices to tend to slide pretty quickly.
http://img11.imageshack.us/i/5870leakedpricingbig.jpg/
A straight conversion puts that at ~£284, a bit steeper than I was hoping but I'll still get one at that.
5850 3 times the current price of a 4850 but less than twice as powerful.....
Not sure where your getting your info
You are both getting your information from speculation & rumour and debating as if it were fact. That being the case, you are both being slightly childlike and impatient in my opinion. Why can't you just wait and see (less than a week so don't panic) what the actual specs are and then perhaps your ramblings will be more informed/less inane.
