http://www.scythe-eu.com/en/products/fans/gentle-typhoon-120-mm.html
I've been hearing a lot about Gentle Typhoon fans for a while now around the interwebs so I though I'd give the 1450rmp version a try in a new build.
Subjectively, in a side by side comparison at 12V with a NF-P12 I found them to not only to push a lot more air, but were also noticably quieter of all things!
And they are ~£7 cheaper then Noctuas too!
OK, it does not come with rubber pins, the cable is a bit short and not nicely braided, they have a massive motor and mounting can be a bit tricky as the frame is not 'ribbed' (so cant be held with rubber pins or clips that hold onto the 'inside' of the frame).
But now I dont see why anyone would want to buy any of the current Noctua fans again for thier asking price?
