i would worry more about temps and voltage rather what it can clock too. Both are on the intel spec sheet.![]()
I've seen people pushing loads more voltage through their chips than what the Intel Spec Sheets say, though they are using extreme cooling..
True mate but he said safe, i would not like to recomend to lets say a newer member of the community to shove 1.x volts etc just cause the XS guys do if you know what im saying![]()
I would say 4.0 using 20X200. That way, your memory will run according to spec. I could be wrong though.
If he is using 1600MHz ram then yes, but tbh, using 191x21 wont make much if any difference to performance.
